Time Before: 0.00219 seconds
Time After: 0.00273 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00281 seconds
Time After: 0.00321 seconds
Time Before: 0.00341 seconds
Time After: 0.00353 seconds
Time Before: 0.00425 seconds
Time After: 0.00669 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00358 seconds
Time After: 0.01010 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01210 seconds
Time After: 0.01251 seconds
Time Before: 0.01486 seconds
Time After: 0.01613 seconds
Time Before: 0.01148 seconds
Time After: 0.01630 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02243 seconds
Time After: 0.02261 seconds
Time Before: 0.02440 seconds
Time After: 0.02568 seconds
Time Before: 0.02844 seconds
Time After: 0.02864 seconds
Time Before: 0.03070 seconds
Time After: 0.03212 seconds
UPDATE session SET lastactivity = 1783059224, location = '/forums/private.php?do=newpm&explain=1&u=91819', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04450 seconds
Time After: 0.04478 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
