Time Before: 0.02433 seconds
Time After: 0.03379 seconds
Time Taken: 0.00946 seconds
Time Before: 0.03389 seconds
Time After: 0.03434 seconds
Time Before: 0.03455 seconds
Time After: 0.03472 seconds
Time Before: 0.03547 seconds
Time After: 0.03791 seconds
Time Taken: 0.00244 seconds
Time Before: 0.03477 seconds
Time After: 0.04191 seconds
Time Taken: 0.00714 seconds
Time Before: 0.05156 seconds
Time After: 0.05193 seconds
Time Before: 0.05327 seconds
Time After: 0.05444 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05096 seconds
Time After: 0.05463 seconds
Time Taken: 0.00367 seconds
Time Before: 0.09192 seconds
Time After: 0.09209 seconds
Time Before: 0.11927 seconds
Time After: 0.12073 seconds
End call of global.php: 0.12268805503845
Time Before: 0.13088 seconds
Time After: 0.13103 seconds
Time Before: 0.13342 seconds
Time After: 0.13487 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=91848'
Time Before: 0.15551 seconds
Time After: 0.15577 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.15459394454956 seconds with 9 queries, spending 0.0080912113189697 doing MySQL queries and 0.14650273323059 doing PHP things.
