Time Before: 0.01923 seconds
Time After: 0.02212 seconds
Time Taken: 0.00289 seconds
Time Before: 0.02222 seconds
Time After: 0.02269 seconds
Time Before: 0.02293 seconds
Time After: 0.02308 seconds
Time Before: 0.02383 seconds
Time After: 0.02643 seconds
Time Taken: 0.00261 seconds
Time Before: 0.02313 seconds
Time After: 0.03085 seconds
Time Taken: 0.00772 seconds
Time Before: 0.03983 seconds
Time After: 0.04029 seconds
Time Before: 0.04269 seconds
Time After: 0.04396 seconds
Time Before: 0.03914 seconds
Time After: 0.04417 seconds
Time Taken: 0.00503 seconds
Time Before: 0.07172 seconds
Time After: 0.07187 seconds
Time Before: 0.08513 seconds
Time After: 0.08649 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.088718891143799
Time Before: 0.09426 seconds
Time After: 0.09442 seconds
Time Before: 0.09677 seconds
Time After: 0.09824 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=91921', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.11906 seconds
Time After: 0.11936 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.11795592308044 seconds with 9 queries, spending 0.0084121227264404 doing MySQL queries and 0.109543800354 doing PHP things.
