Time Before: 0.00158 seconds
Time After: 0.00204 seconds
Time Before: 0.00210 seconds
Time After: 0.00249 seconds
Time Before: 0.00269 seconds
Time After: 0.00286 seconds
Time Before: 0.00401 seconds
Time After: 0.00789 seconds
Time Taken: 0.00388 seconds
Time Before: 0.00291 seconds
Time After: 0.01147 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01347 seconds
Time After: 0.01390 seconds
Time Before: 0.01726 seconds
Time After: 0.01846 seconds
Time Before: 0.01282 seconds
Time After: 0.01872 seconds
Time Taken: 0.00591 seconds
Time Before: 0.02616 seconds
Time After: 0.02633 seconds
Time Before: 0.02818 seconds
Time After: 0.02941 seconds
Time Before: 0.03255 seconds
Time After: 0.03273 seconds
Time Before: 0.03559 seconds
Time After: 0.03717 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1789113812, location = '/forums/private.php?do=newpm&explain=1&u=91979' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05083 seconds
Time After: 0.05123 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
