Time Before: 0.01982 seconds
Time After: 0.02467 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02480 seconds
Time After: 0.02530 seconds
Time Before: 0.02552 seconds
Time After: 0.02567 seconds
Time Before: 0.02641 seconds
Time After: 0.02871 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02572 seconds
Time After: 0.03300 seconds
Time Taken: 0.00727 seconds
Time Before: 0.04013 seconds
Time After: 0.04057 seconds
Time Before: 0.04341 seconds
Time After: 0.04472 seconds
Time Before: 0.03944 seconds
Time After: 0.04491 seconds
Time Taken: 0.00547 seconds
Time Before: 0.07199 seconds
Time After: 0.07212 seconds
Time Before: 0.08701 seconds
Time After: 0.08826 seconds
Time Before: 0.09899 seconds
Time After: 0.09913 seconds
Time Before: 0.10187 seconds
Time After: 0.10331 seconds
UPDATE session SET lastactivity = 1783180877, location = '/forums/private.php?do=newpm&explain=1&u=92104', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.11923 seconds
Time After: 0.11967 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
