Time Before: 0.01163 seconds
Time After: 0.01526 seconds
Time Taken: 0.00364 seconds
Time Before: 0.01536 seconds
Time After: 0.01578 seconds
Time Before: 0.01620 seconds
Time After: 0.01638 seconds
Time Before: 0.01720 seconds
Time After: 0.01916 seconds
Time Taken: 0.00196 seconds
Time Before: 0.01645 seconds
Time After: 0.02384 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02932 seconds
Time After: 0.02973 seconds
Time Before: 0.03262 seconds
Time After: 0.03381 seconds
Time Before: 0.02859 seconds
Time After: 0.03408 seconds
Time Taken: 0.00549 seconds
Time Before: 0.05458 seconds
Time After: 0.05475 seconds
Time Before: 0.06409 seconds
Time After: 0.06533 seconds
Time Before: 0.07342 seconds
Time After: 0.07359 seconds
Time Before: 0.07643 seconds
Time After: 0.07786 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=9220', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.09448 seconds
Time After: 0.09477 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
