Time Before: 0.00147 seconds
Time After: 0.00192 seconds
Time Before: 0.00200 seconds
Time After: 0.00240 seconds
Time Before: 0.00262 seconds
Time After: 0.00278 seconds
Time Before: 0.00353 seconds
Time After: 0.00725 seconds
Time Taken: 0.00372 seconds
Time Before: 0.00282 seconds
Time After: 0.01123 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01307 seconds
Time After: 0.01349 seconds
Time Before: 0.01693 seconds
Time After: 0.01819 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01245 seconds
Time After: 0.01836 seconds
Time Taken: 0.00591 seconds
Memory After: 2,261.836 KB
Time Before: 0.02469 seconds
Time After: 0.02487 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02841 seconds
Time After: 0.02970 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03360 seconds
Time After: 0.03374 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03586 seconds
Time After: 0.03731 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789123886, location = '/forums/private.php?do=newpm&explain=1&u=92225', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05009 seconds
Time After: 0.05043 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
