Time Before: 0.00579 seconds
Time After: 0.00819 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00832 seconds
Time After: 0.00876 seconds
Time Before: 0.00903 seconds
Time After: 0.00920 seconds
Time Before: 0.00998 seconds
Time After: 0.01202 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00928 seconds
Time After: 0.01725 seconds
Time Taken: 0.00797 seconds
Time Before: 0.02294 seconds
Time After: 0.02315 seconds
Time Before: 0.02588 seconds
Time After: 0.02716 seconds
Time Before: 0.02210 seconds
Time After: 0.02745 seconds
Time Taken: 0.00535 seconds
Memory After: 2,262.445 KB
Memory Used: 132.898 KB
Time Before: 0.03705 seconds
Time After: 0.03719 seconds
Memory Before: 2,815.961 KB
Memory After: 2,816.477 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"14.95,\";s:9:\"lastcheck\";i:1782960347;}', 1)Time Before: 0.04571 seconds
Time After: 0.04622 seconds
Memory Before: 2,817.227 KB
Memory After: 2,817.477 KB
Memory Used: 0.250 KB
Time Before: 0.07842 seconds
Time After: 0.07972 seconds
Memory Before: 2,904.531 KB
Memory After: 2,905.125 KB
Time Before: 0.08497 seconds
Time After: 0.08524 seconds
Memory Before: 3,541.344 KB
Memory After: 3,541.773 KB
Time Before: 0.08842 seconds
Time After: 0.09001 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,822.883 KB
Memory After: 3,824.570 KB
UPDATE session SET lastactivity = 1782960347, location = '/forums/private.php?do=newpm&explain=1&u=92285', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.10986 seconds
Time After: 0.11016 seconds
Memory Before: 4,297.820 KB
Memory After: 4,298.031 KB
