Time Before: 0.02613 seconds
Time After: 0.03398 seconds
Time Taken: 0.00785 seconds
Time Before: 0.03410 seconds
Time After: 0.03452 seconds
Time Before: 0.03479 seconds
Time After: 0.03494 seconds
Time Before: 0.03565 seconds
Time After: 0.03754 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03501 seconds
Time After: 0.04143 seconds
Time Taken: 0.00642 seconds
Time Before: 0.04743 seconds
Time After: 0.04793 seconds
Time Before: 0.05024 seconds
Time After: 0.05146 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04672 seconds
Time After: 0.05171 seconds
Time Taken: 0.00499 seconds
Memory After: 2,261.836 KB
Time Before: 0.08845 seconds
Time After: 0.08861 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.11418 seconds
Time After: 0.11540 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.12714 seconds
Time After: 0.12730 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.12945 seconds
Time After: 0.13089 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789142724, location = '/forums/private.php?do=newpm&explain=1&u=92377' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.15100 seconds
Time After: 0.15126 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
