Time Before: 0.00213 seconds
Time After: 0.00277 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00288 seconds
Time After: 0.00355 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00384 seconds
Time After: 0.00399 seconds
Time Before: 0.00467 seconds
Time After: 0.00753 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00404 seconds
Time After: 0.01094 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01275 seconds
Time After: 0.01308 seconds
Time Before: 0.01547 seconds
Time After: 0.01674 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01215 seconds
Time After: 0.01691 seconds
Time Taken: 0.00476 seconds
Memory After: 2,261.836 KB
Time Before: 0.02227 seconds
Time After: 0.02241 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02451 seconds
Time After: 0.02578 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.027405023574829
Time Before: 0.02883 seconds
Time After: 0.02898 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03094 seconds
Time After: 0.03247 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788957176, location = '/forums/private.php?do=newpm&explain=1&u=92425', badlocation = 1
Time Before: 0.04483 seconds
Time After: 0.04528 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.043889999389648 seconds with 9 queries, spending 0.0088541507720947 doing MySQL queries and 0.035035848617554 doing PHP things.
