Time Before: 0.00146 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00242 seconds
Time Before: 0.00262 seconds
Time After: 0.00277 seconds
Time Before: 0.00344 seconds
Time After: 0.00608 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00281 seconds
Time After: 0.01078 seconds
Time Taken: 0.00796 seconds
Time Before: 0.01311 seconds
Time After: 0.01355 seconds
Time Before: 0.01520 seconds
Time After: 0.01661 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01240 seconds
Time After: 0.01686 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02217 seconds
Time After: 0.02241 seconds
Time Before: 0.02422 seconds
Time After: 0.02567 seconds
Time Before: 0.02973 seconds
Time After: 0.02987 seconds
Time Before: 0.03298 seconds
Time After: 0.03443 seconds
UPDATE session SET lastactivity = 1789147511, location = '/forums/private.php?do=newpm&explain=1&u=92659' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04952 seconds
Time After: 0.05004 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
