Time Before: 0.03013 seconds
Time After: 0.03922 seconds
Time Taken: 0.00909 seconds
Time Before: 0.03932 seconds
Time After: 0.04078 seconds
Time Before: 0.04103 seconds
Time After: 0.04117 seconds
Time Before: 0.04196 seconds
Time After: 0.04426 seconds
Time Taken: 0.00230 seconds
Time Before: 0.04124 seconds
Time After: 0.04809 seconds
Time Taken: 0.00685 seconds
Time Before: 0.05795 seconds
Time After: 0.05836 seconds
Time Before: 0.06121 seconds
Time After: 0.06237 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05720 seconds
Time After: 0.06257 seconds
Time Taken: 0.00536 seconds
Time Before: 0.10289 seconds
Time After: 0.10304 seconds
Time Before: 0.12611 seconds
Time After: 0.12734 seconds
Time Before: 0.13658 seconds
Time After: 0.13676 seconds
Time Before: 0.13905 seconds
Time After: 0.14051 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=92747', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.15810 seconds
Time After: 0.15838 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
