Time Before: 0.02168 seconds
Time After: 0.02895 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02904 seconds
Time After: 0.02952 seconds
Time Before: 0.02978 seconds
Time After: 0.02995 seconds
Time Before: 0.03082 seconds
Time After: 0.03337 seconds
Time Taken: 0.00255 seconds
Time Before: 0.03000 seconds
Time After: 0.03733 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04819 seconds
Time After: 0.04868 seconds
Time Before: 0.05127 seconds
Time After: 0.05263 seconds
Time Taken: 0.00136 seconds
Time Before: 0.04746 seconds
Time After: 0.05285 seconds
Time Taken: 0.00539 seconds
Time Before: 0.09096 seconds
Time After: 0.09117 seconds
Time Before: 0.11455 seconds
Time After: 0.11583 seconds
End call of global.php: 0.11804509162903
Time Before: 0.12360 seconds
Time After: 0.12376 seconds
Time Before: 0.12637 seconds
Time After: 0.12782 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=93014', badlocation = 1
Time Before: 0.14805 seconds
Time After: 0.14835 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.14700698852539 seconds with 9 queries, spending 0.0084514617919922 doing MySQL queries and 0.1385555267334 doing PHP things.
