Time Before: 0.00150 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00254 seconds
Time Before: 0.00281 seconds
Time After: 0.00293 seconds
Time Before: 0.00375 seconds
Time After: 0.00626 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00299 seconds
Time After: 0.00974 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01185 seconds
Time After: 0.01228 seconds
Time Before: 0.01489 seconds
Time After: 0.01616 seconds
Time Before: 0.01100 seconds
Time After: 0.01634 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02191 seconds
Time After: 0.02203 seconds
Time Before: 0.02436 seconds
Time After: 0.02561 seconds
End call of global.php: 0.027360916137695
Time Before: 0.02875 seconds
Time After: 0.02887 seconds
Time Before: 0.03083 seconds
Time After: 0.03229 seconds
SET lastactivity = 1783185327, location = '/forums/private.php?do=newpm&explain=1&u=93051'
Time Before: 0.04745 seconds
Time After: 0.04780 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.046540021896362 seconds with 9 queries, spending 0.0081217288970947 doing MySQL queries and 0.038418292999268 doing PHP things.
