Time Before: 0.01267 seconds
Time After: 0.01652 seconds
Time Taken: 0.00385 seconds
Time Before: 0.01663 seconds
Time After: 0.01706 seconds
Time Before: 0.01729 seconds
Time After: 0.01742 seconds
Time Before: 0.01817 seconds
Time After: 0.02037 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01748 seconds
Time After: 0.02415 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02946 seconds
Time After: 0.02991 seconds
Time Before: 0.03352 seconds
Time After: 0.03516 seconds
Time Taken: 0.00164 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02873 seconds
Time After: 0.03541 seconds
Memory After: 2,261.719 KB
Time Before: 0.05543 seconds
Time After: 0.05556 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06795 seconds
Time After: 0.06918 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.071052074432373
Time Before: 0.07701 seconds
Time After: 0.07719 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07983 seconds
Time After: 0.08126 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=93079'
Time Before: 0.09708 seconds
Time After: 0.09799 seconds
Time Taken: 0.00091 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.096101045608521 seconds with 9 queries, spending 0.0087306499481201 doing MySQL queries and 0.0873703956604 doing PHP things.
