Time Before: 0.01718 seconds
Time After: 0.02280 seconds
Time Taken: 0.00562 seconds
Time Before: 0.02290 seconds
Time After: 0.02342 seconds
Time Before: 0.02369 seconds
Time After: 0.02386 seconds
Time Before: 0.02470 seconds
Time After: 0.03123 seconds
Time Taken: 0.00653 seconds
Time Before: 0.02394 seconds
Time After: 0.03661 seconds
Time Taken: 0.01267 seconds
Time Before: 0.04150 seconds
Time After: 0.04191 seconds
Time Before: 0.04438 seconds
Time After: 0.04562 seconds
Time Before: 0.04076 seconds
Time After: 0.04589 seconds
Time Taken: 0.00513 seconds
Time Before: 0.08076 seconds
Time After: 0.08092 seconds
Time Before: 0.09703 seconds
Time After: 0.09828 seconds
Time Before: 0.11021 seconds
Time After: 0.11041 seconds
Time Before: 0.11317 seconds
Time After: 0.11462 seconds
UPDATE session SET lastactivity = 1785268066, location = '/forums/private.php?do=newpm&explain=1&u=9309' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.13497 seconds
Time After: 0.13531 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
