Time Before: 0.00661 seconds
Time After: 0.01005 seconds
Time Taken: 0.00344 seconds
Time Before: 0.01022 seconds
Time After: 0.01072 seconds
Time Before: 0.01093 seconds
Time After: 0.01107 seconds
Time Before: 0.01183 seconds
Time After: 0.01436 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01114 seconds
Time After: 0.01872 seconds
Time Taken: 0.00757 seconds
Time Before: 0.02246 seconds
Time After: 0.02270 seconds
Time Before: 0.02557 seconds
Time After: 0.02677 seconds
Time Before: 0.02172 seconds
Time After: 0.02701 seconds
Time Taken: 0.00529 seconds
Time Before: 0.04739 seconds
Time After: 0.04754 seconds
Time Before: 0.05495 seconds
Time After: 0.05620 seconds
End call of global.php: 0.058325052261353
Time Before: 0.06186 seconds
Time After: 0.06200 seconds
Time Before: 0.06425 seconds
Time After: 0.06578 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=93323'
Time Before: 0.08319 seconds
Time After: 0.08342 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.082010984420776 seconds with 9 queries, spending 0.0079257488250732 doing MySQL queries and 0.074085235595703 doing PHP things.
