Time Before: 0.00131 seconds
Time After: 0.00191 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00198 seconds
Time After: 0.00245 seconds
Time Before: 0.00270 seconds
Time After: 0.00283 seconds
Time Before: 0.00385 seconds
Time After: 0.00696 seconds
Time Taken: 0.00311 seconds
Time Before: 0.00291 seconds
Time After: 0.01172 seconds
Time Taken: 0.00881 seconds
Time Before: 0.01377 seconds
Time After: 0.01424 seconds
Time Before: 0.01728 seconds
Time After: 0.01853 seconds
Time Before: 0.01298 seconds
Time After: 0.01877 seconds
Time Taken: 0.00579 seconds
Time Before: 0.02524 seconds
Time After: 0.02539 seconds
Time Before: 0.02792 seconds
Time After: 0.02917 seconds
Time Before: 0.03296 seconds
Time After: 0.03315 seconds
Time Before: 0.03596 seconds
Time After: 0.03745 seconds
UPDATE session SET lastactivity = 1776514723, location = '/forums/private.php?do=newpm&explain=1&u=93387', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.05046 seconds
Time After: 0.05097 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
