Time Before: 0.00480 seconds
Time After: 0.00606 seconds
Time Before: 0.00617 seconds
Time After: 0.00663 seconds
Time Before: 0.00686 seconds
Time After: 0.00701 seconds
Time Before: 0.00781 seconds
Time After: 0.01047 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00709 seconds
Time After: 0.01388 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01740 seconds
Time After: 0.01782 seconds
Time Before: 0.02030 seconds
Time After: 0.02157 seconds
Time Before: 0.01683 seconds
Time After: 0.02174 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02935 seconds
Time After: 0.02950 seconds
Time Before: 0.03281 seconds
Time After: 0.03429 seconds
End call of global.php: 0.03597092628479
Time Before: 0.03805 seconds
Time After: 0.03818 seconds
Time Before: 0.04024 seconds
Time After: 0.04226 seconds
Time Taken: 0.00202 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=93404'
Time Before: 0.05615 seconds
Time After: 0.05686 seconds
Time Taken: 0.00071 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.054711818695068 seconds with 9 queries, spending 0.0094504356384277 doing MySQL queries and 0.045261383056641 doing PHP things.
