Time Before: 0.02082 seconds
Time After: 0.03065 seconds
Time Taken: 0.00983 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03076 seconds
Time After: 0.03126 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03150 seconds
Time After: 0.03167 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03259 seconds
Time After: 0.03458 seconds
Time Taken: 0.00199 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03177 seconds
Time After: 0.03852 seconds
Time Taken: 0.00675 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04695 seconds
Time After: 0.04739 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04978 seconds
Time After: 0.05097 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04620 seconds
Time After: 0.05116 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08172 seconds
Time After: 0.08191 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.12614 seconds
Time After: 0.12739 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.12932777404785
Time Before: 0.14609 seconds
Time After: 0.14626 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.15064 seconds
Time After: 0.15229 seconds
Time Taken: 0.00165 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=93644', badlocation = 1
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.17398 seconds
Time After: 0.17428 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.17286777496338 seconds with 9 queries, spending 0.0078494548797607 doing MySQL queries and 0.16501832008362 doing PHP things.
