Time Before: 0.00281 seconds
Time After: 0.00368 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00378 seconds
Time After: 0.00433 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00464 seconds
Time After: 0.00491 seconds
Time Before: 0.00576 seconds
Time After: 0.00812 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00500 seconds
Time After: 0.01325 seconds
Time Taken: 0.00825 seconds
Time Before: 0.01502 seconds
Time After: 0.01522 seconds
Time Before: 0.01774 seconds
Time After: 0.01898 seconds
Time Before: 0.01440 seconds
Time After: 0.01925 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02622 seconds
Time After: 0.02639 seconds
Time Before: 0.02938 seconds
Time After: 0.03068 seconds
Time Before: 0.03499 seconds
Time After: 0.03515 seconds
Time Before: 0.03720 seconds
Time After: 0.03865 seconds
UPDATE session SET lastactivity = 1776805000, location = '/forums/private.php?do=newpm&explain=1&u=93646' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.05747 seconds
Time After: 0.05789 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
