Time Before: 0.00130 seconds
Time After: 0.00176 seconds
Time Before: 0.00183 seconds
Time After: 0.00229 seconds
Time Before: 0.00255 seconds
Time After: 0.00269 seconds
Time Before: 0.00353 seconds
Time After: 0.00641 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00276 seconds
Time After: 0.01129 seconds
Time Taken: 0.00853 seconds
Time Before: 0.01320 seconds
Time After: 0.01360 seconds
Time Before: 0.01620 seconds
Time After: 0.01740 seconds
Time Before: 0.01249 seconds
Time After: 0.01766 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02389 seconds
Time After: 0.02404 seconds
Time Before: 0.02659 seconds
Time After: 0.02794 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03210 seconds
Time After: 0.03226 seconds
Time Before: 0.03472 seconds
Time After: 0.03611 seconds
Time Taken: 0.00139 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=93725', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04997 seconds
Time After: 0.05020 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
