Time Before: 0.00138 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00241 seconds
Time Before: 0.00268 seconds
Time After: 0.00282 seconds
Time Before: 0.00379 seconds
Time After: 0.00661 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00289 seconds
Time After: 0.01127 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01318 seconds
Time After: 0.01358 seconds
Time Before: 0.01601 seconds
Time After: 0.01735 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01249 seconds
Time After: 0.01759 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02543 seconds
Time After: 0.02559 seconds
Time Before: 0.02752 seconds
Time After: 0.02879 seconds
Time Before: 0.03308 seconds
Time After: 0.03330 seconds
Time Before: 0.03596 seconds
Time After: 0.03746 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1773210892, location = '/forums/private.php?do=newpm&explain=1&u=93763' WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.05411 seconds
Time After: 0.05458 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
