Time Before: 0.00894 seconds
Time After: 0.01081 seconds
Time Taken: 0.00187 seconds
Time Before: 0.01092 seconds
Time After: 0.01134 seconds
Time Before: 0.01161 seconds
Time After: 0.01174 seconds
Time Before: 0.01246 seconds
Time After: 0.01488 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01179 seconds
Time After: 0.01831 seconds
Time Taken: 0.00651 seconds
Time Before: 0.02303 seconds
Time After: 0.02322 seconds
Time Before: 0.02579 seconds
Time After: 0.02700 seconds
Time Before: 0.02227 seconds
Time After: 0.02720 seconds
Time Taken: 0.00494 seconds
Time Before: 0.04115 seconds
Time After: 0.04128 seconds
Time Before: 0.04733 seconds
Time After: 0.04856 seconds
End call of global.php: 0.050700187683105
Time Before: 0.05410 seconds
Time After: 0.05424 seconds
Time Before: 0.05654 seconds
Time After: 0.05798 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=93872'
Time Before: 0.07399 seconds
Time After: 0.07422 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.073080062866211 seconds with 9 queries, spending 0.0075418949127197 doing MySQL queries and 0.065538167953491 doing PHP things.
