Time Before: 0.00146 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00241 seconds
Time Before: 0.00268 seconds
Time After: 0.00282 seconds
Time Before: 0.00357 seconds
Time After: 0.00663 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00288 seconds
Time After: 0.01024 seconds
Time Taken: 0.00736 seconds
Time Before: 0.01222 seconds
Time After: 0.01242 seconds
Time Before: 0.01522 seconds
Time After: 0.01648 seconds
Time Before: 0.01160 seconds
Time After: 0.01681 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02178 seconds
Time After: 0.02191 seconds
Time Before: 0.02386 seconds
Time After: 0.02515 seconds
End call of global.php: 0.027497053146362
Time Before: 0.02876 seconds
Time After: 0.02889 seconds
Time Before: 0.03100 seconds
Time After: 0.03253 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=94117'
Time Before: 0.04616 seconds
Time After: 0.04643 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045091152191162 seconds with 9 queries, spending 0.0084438323974609 doing MySQL queries and 0.036647319793701 doing PHP things.
