Time Before: 0.01940 seconds
Time After: 0.02314 seconds
Time Taken: 0.00374 seconds
Time Before: 0.02321 seconds
Time After: 0.02366 seconds
Time Before: 0.02393 seconds
Time After: 0.02407 seconds
Time Before: 0.02488 seconds
Time After: 0.02724 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02412 seconds
Time After: 0.03111 seconds
Time Taken: 0.00699 seconds
Time Before: 0.03775 seconds
Time After: 0.03820 seconds
Time Before: 0.04112 seconds
Time After: 0.04232 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03694 seconds
Time After: 0.04255 seconds
Time Taken: 0.00561 seconds
Memory After: 2,261.836 KB
Time Before: 0.07540 seconds
Time After: 0.07557 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09303 seconds
Time After: 0.09439 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10397 seconds
Time After: 0.10411 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10643 seconds
Time After: 0.10791 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788935654, location = '/forums/private.php?do=newpm&explain=1&u=94199' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12507 seconds
Time After: 0.12539 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
