Time Before: 0.02966 seconds
Time After: 0.04687 seconds
Time Taken: 0.01721 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.04696 seconds
Time After: 0.04753 seconds
Time Taken: 0.00058 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.04790 seconds
Time After: 0.04806 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.04877 seconds
Time After: 0.05163 seconds
Time Taken: 0.00285 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.04813 seconds
Time After: 0.05576 seconds
Time Taken: 0.00764 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.07223 seconds
Time After: 0.07271 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.07534 seconds
Time After: 0.07657 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.07150 seconds
Time After: 0.07676 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.13018 seconds
Time After: 0.13035 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.15865 seconds
Time After: 0.15988 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.16222500801086
Time Before: 0.17497 seconds
Time After: 0.17517 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.17777 seconds
Time After: 0.17922 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=94284'
Time Before: 0.19811 seconds
Time After: 0.19840 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.19714307785034 seconds with 9 queries, spending 0.0086588859558105 doing MySQL queries and 0.18848419189453 doing PHP things.
