Time Before: 0.00577 seconds
Time After: 0.00807 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00814 seconds
Time After: 0.00863 seconds
Time Before: 0.00883 seconds
Time After: 0.00895 seconds
Time Before: 0.00962 seconds
Time After: 0.01192 seconds
Time Before: 0.00900 seconds
Time After: 0.01646 seconds
Time Taken: 0.00746 seconds
Time Before: 0.01966 seconds
Time After: 0.01988 seconds
Time Before: 0.02221 seconds
Time After: 0.02347 seconds
Time Before: 0.01898 seconds
Time After: 0.02372 seconds
Time Taken: 0.00474 seconds
Time Before: 0.03887 seconds
Time After: 0.03917 seconds
Time Before: 0.16692 seconds
Time After: 0.16826 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.17108917236328
Time Before: 0.17357 seconds
Time After: 0.17374 seconds
Time Before: 0.17635 seconds
Time After: 0.17781 seconds
SET lastactivity = 1776666917, location = '/forums/private.php?do=newpm&explain=1&u=94419', badlocation = 1
Time Before: 0.19231 seconds
Time After: 0.19252 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.19138503074646 seconds with 9 queries, spending 0.0078792572021484 doing MySQL queries and 0.18350577354431 doing PHP things.
