Time Before: 0.00144 seconds
Time After: 0.00195 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00201 seconds
Time After: 0.00239 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00266 seconds
Time After: 0.00280 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00343 seconds
Time After: 0.00562 seconds
Time Taken: 0.00219 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00285 seconds
Time After: 0.00906 seconds
Time Taken: 0.00621 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01106 seconds
Time After: 0.01127 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01387 seconds
Time After: 0.01516 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01037 seconds
Time After: 0.01542 seconds
Time Taken: 0.00506 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02255 seconds
Time After: 0.02276 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02472 seconds
Time After: 0.02602 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.028067827224731
Time Before: 0.02930 seconds
Time After: 0.02947 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03157 seconds
Time After: 0.03400 seconds
Time Taken: 0.00243 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=94442'
Time Before: 0.05028 seconds
Time After: 0.05077 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.049147844314575 seconds with 9 queries, spending 0.0088191032409668 doing MySQL queries and 0.040328741073608 doing PHP things.
