Time Before: 0.00211 seconds
Time After: 0.00327 seconds
Time Taken: 0.00117 seconds
Time Before: 0.00338 seconds
Time After: 0.00387 seconds
Time Before: 0.00416 seconds
Time After: 0.00433 seconds
Time Before: 0.00522 seconds
Time After: 0.00801 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00441 seconds
Time After: 0.01279 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01499 seconds
Time After: 0.01535 seconds
Time Before: 0.01811 seconds
Time After: 0.01928 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01436 seconds
Time After: 0.01945 seconds
Time Taken: 0.00508 seconds
Memory After: 2,261.719 KB
Time Before: 0.02494 seconds
Time After: 0.02520 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02714 seconds
Time After: 0.02838 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.029985904693604
Time Before: 0.03109 seconds
Time After: 0.03126 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03316 seconds
Time After: 0.03459 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=9445', badlocation = 1
Time Before: 0.04677 seconds
Time After: 0.04715 seconds
Memory Before: 4,287.508 KB
Memory After: 4,287.734 KB
Page generated in 0.045889854431152 seconds with 9 queries, spending 0.0084753036499023 doing MySQL queries and 0.03741455078125 doing PHP things.
