Time Before: 0.00131 seconds
Time After: 0.00176 seconds
Time Before: 0.00183 seconds
Time After: 0.00215 seconds
Time Before: 0.00232 seconds
Time After: 0.00243 seconds
Time Before: 0.00318 seconds
Time After: 0.00583 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00248 seconds
Time After: 0.01078 seconds
Time Taken: 0.00829 seconds
Time Before: 0.01325 seconds
Time After: 0.01371 seconds
Time Before: 0.01626 seconds
Time After: 0.01746 seconds
Time Before: 0.01252 seconds
Time After: 0.01769 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02462 seconds
Time After: 0.02481 seconds
Time Before: 0.02674 seconds
Time After: 0.02799 seconds
End call of global.php: 0.029643058776855
Time Before: 0.03097 seconds
Time After: 0.03112 seconds
Time Before: 0.03360 seconds
Time After: 0.03501 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=94459'
Time Before: 0.04735 seconds
Time After: 0.04760 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.046458005905151 seconds with 9 queries, spending 0.0079877376556396 doing MySQL queries and 0.038470268249512 doing PHP things.
