Time Before: 0.01154 seconds
Time After: 0.01663 seconds
Time Taken: 0.00510 seconds
Time Before: 0.01675 seconds
Time After: 0.01729 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01757 seconds
Time After: 0.01775 seconds
Time Before: 0.01863 seconds
Time After: 0.02100 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01782 seconds
Time After: 0.02481 seconds
Time Taken: 0.00698 seconds
Time Before: 0.03133 seconds
Time After: 0.03158 seconds
Time Before: 0.03422 seconds
Time After: 0.03549 seconds
Time Before: 0.03059 seconds
Time After: 0.03569 seconds
Time Before: 0.05350 seconds
Time After: 0.05371 seconds
Time Before: 0.15719 seconds
Time After: 0.15841 seconds
End call of global.php: 0.16139888763428
Time Before: 0.16849 seconds
Time After: 0.16864 seconds
Time Before: 0.17114 seconds
Time After: 0.17255 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=94633', badlocation = 1
Time Before: 0.18819 seconds
Time After: 0.18846 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.18720293045044 seconds with 9 queries, spending 0.007868766784668 doing MySQL queries and 0.17933416366577 doing PHP things.
