Time Before: 0.00156 seconds
Time After: 0.00213 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00220 seconds
Time After: 0.00266 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00373 seconds
Time After: 0.00626 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00311 seconds
Time After: 0.01011 seconds
Time Taken: 0.00700 seconds
Time Before: 0.01204 seconds
Time After: 0.01244 seconds
Time Before: 0.01506 seconds
Time After: 0.01631 seconds
Time Before: 0.01133 seconds
Time After: 0.01648 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02171 seconds
Time After: 0.02187 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"6.45,\";s:9:\"lastcheck\";i:1789061643;}', 1)Time Before: 0.02815 seconds
Time After: 0.02896 seconds
Time Taken: 0.00082 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03193 seconds
Time After: 0.03324 seconds
Memory Before: 3,526.430 KB
Memory After: 3,527.023 KB
Time Before: 0.03814 seconds
Time After: 0.03834 seconds
Memory Before: 4,164.305 KB
Memory After: 4,164.734 KB
Time Before: 0.04147 seconds
Time After: 0.04291 seconds
Memory Before: 4,446.094 KB
Memory After: 4,447.781 KB
UPDATE session SET lastactivity = 1789061643, location = '/forums/private.php?do=newpm&explain=1&u=94673' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05879 seconds
Time After: 0.05914 seconds
Memory Before: 4,919.758 KB
Memory After: 4,919.984 KB
