Time Before: 0.01290 seconds
Time After: 0.01966 seconds
Time Taken: 0.00676 seconds
Time Before: 0.01974 seconds
Time After: 0.02016 seconds
Time Before: 0.02037 seconds
Time After: 0.02053 seconds
Time Before: 0.02135 seconds
Time After: 0.02373 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02060 seconds
Time After: 0.02930 seconds
Time Taken: 0.00870 seconds
Time Before: 0.03570 seconds
Time After: 0.03620 seconds
Time Before: 0.03760 seconds
Time After: 0.03877 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03486 seconds
Time After: 0.03898 seconds
Time Taken: 0.00412 seconds
Time Before: 0.06273 seconds
Time After: 0.06289 seconds
Time Before: 0.07442 seconds
Time After: 0.07572 seconds
Time Taken: 0.00131 seconds
Time Before: 0.08358 seconds
Time After: 0.08374 seconds
Time Before: 0.08618 seconds
Time After: 0.08765 seconds
UPDATE session SET lastactivity = 1784710212, location = '/forums/private.php?do=newpm&explain=1&u=94723', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.10796 seconds
Time After: 0.10825 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
