Time Before: 0.00161 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00261 seconds
Time Before: 0.00284 seconds
Time After: 0.00294 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00375 seconds
Time After: 0.00655 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00299 seconds
Time After: 0.01037 seconds
Time Taken: 0.00738 seconds
Time Before: 0.01214 seconds
Time After: 0.01234 seconds
Time Before: 0.01490 seconds
Time After: 0.01611 seconds
Time Before: 0.01157 seconds
Time After: 0.01630 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02132 seconds
Time After: 0.02148 seconds
Time Before: 0.02341 seconds
Time After: 0.02462 seconds
End call of global.php: 0.026257038116455
Time Before: 0.02743 seconds
Time After: 0.02755 seconds
Time Before: 0.02954 seconds
Time After: 0.03096 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=94788', badlocation = 1
Time Before: 0.04575 seconds
Time After: 0.04631 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.044841051101685 seconds with 9 queries, spending 0.0082592964172363 doing MySQL queries and 0.036581754684448 doing PHP things.
