Time Before: 0.01002 seconds
Time After: 0.01401 seconds
Time Taken: 0.00400 seconds
Time Before: 0.01410 seconds
Time After: 0.01471 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01508 seconds
Time After: 0.01535 seconds
Time Before: 0.01609 seconds
Time After: 0.01833 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01540 seconds
Time After: 0.02239 seconds
Time Taken: 0.00698 seconds
Time Before: 0.02996 seconds
Time After: 0.03035 seconds
Time Before: 0.03308 seconds
Time After: 0.03509 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02930 seconds
Time After: 0.03532 seconds
Time Taken: 0.00602 seconds
Memory After: 2,261.836 KB
Time Before: 0.05677 seconds
Time After: 0.05694 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"30.05,\";s:9:\"lastcheck\";i:1788848515;}', 1)
Time Before: 0.07484 seconds
Time After: 0.07521 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.08960 seconds
Time After: 0.09088 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
End call of global.php: 0.094034910202026
Time Before: 0.10119 seconds
Time After: 0.10144 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.10410 seconds
Time After: 0.10556 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
SET lastactivity = 1788848515, location = '/forums/private.php?do=newpm&explain=1&u=94859'
Time Before: 0.12327 seconds
Time After: 0.12352 seconds
Memory Before: 4,296.148 KB
Memory After: 4,296.375 KB
Page generated in 0.12227392196655 seconds with 10 queries, spending 0.0093023777008057 doing MySQL queries and 0.11297154426575 doing PHP things.
