Time Before: 0.01038 seconds
Time After: 0.01748 seconds
Time Taken: 0.00710 seconds
Time Before: 0.01762 seconds
Time After: 0.01809 seconds
Time Before: 0.01835 seconds
Time After: 0.01849 seconds
Time Before: 0.01925 seconds
Time After: 0.02120 seconds
Time Taken: 0.00195 seconds
Time Before: 0.01857 seconds
Time After: 0.02567 seconds
Time Taken: 0.00709 seconds
Time Before: 0.03502 seconds
Time After: 0.03546 seconds
Time Before: 0.03793 seconds
Time After: 0.03918 seconds
Time Before: 0.03442 seconds
Time After: 0.03943 seconds
Time Taken: 0.00501 seconds
Time Before: 0.05666 seconds
Time After: 0.05682 seconds
Time Before: 0.07821 seconds
Time After: 0.07946 seconds
Time Before: 0.08550 seconds
Time After: 0.08565 seconds
Time Before: 0.08830 seconds
Time After: 0.08976 seconds
UPDATE session SET lastactivity = 1789116728, location = '/forums/private.php?do=newpm&explain=1&u=95147' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10924 seconds
Time After: 0.10960 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
