Time Before: 0.00274 seconds
Time After: 0.00367 seconds
Time Taken: 0.00093 seconds
Time Before: 0.00375 seconds
Time After: 0.00429 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00474 seconds
Time After: 0.00500 seconds
Time Before: 0.00569 seconds
Time After: 0.00836 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00505 seconds
Time After: 0.01179 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01379 seconds
Time After: 0.01421 seconds
Time Before: 0.01688 seconds
Time After: 0.01810 seconds
Time Before: 0.01311 seconds
Time After: 0.01832 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02363 seconds
Time After: 0.02378 seconds
Time Before: 0.02556 seconds
Time After: 0.02676 seconds
End call of global.php: 0.028401136398315
Time Before: 0.02968 seconds
Time After: 0.02983 seconds
Time Before: 0.03267 seconds
Time After: 0.03411 seconds
SET lastactivity = 1788979026, location = '/forums/private.php?do=newpm&explain=1&u=95222', badlocation = 1
Time Before: 0.04801 seconds
Time After: 0.04827 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.047072172164917 seconds with 9 queries, spending 0.0083138942718506 doing MySQL queries and 0.038758277893066 doing PHP things.
