Time Before: 0.00474 seconds
Time After: 0.00621 seconds
Time Before: 0.00631 seconds
Time After: 0.00668 seconds
Time Before: 0.00690 seconds
Time After: 0.00705 seconds
Time Before: 0.00793 seconds
Time After: 0.01076 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00712 seconds
Time After: 0.01628 seconds
Time Taken: 0.00916 seconds
Time Before: 0.01928 seconds
Time After: 0.01965 seconds
Time Before: 0.02272 seconds
Time After: 0.02400 seconds
Time Before: 0.01849 seconds
Time After: 0.02428 seconds
Time Taken: 0.00580 seconds
Time Before: 0.03663 seconds
Time After: 0.03686 seconds
Time Before: 0.04244 seconds
Time After: 0.04365 seconds
End call of global.php: 0.046012878417969
Time Before: 0.04847 seconds
Time After: 0.04861 seconds
Time Before: 0.05152 seconds
Time After: 0.05308 seconds
Time Taken: 0.00155 seconds
SET lastactivity = 1782952925, location = '/forums/private.php?do=newpm&explain=1&u=95357'
Time Before: 0.07276 seconds
Time After: 0.07312 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.071354866027832 seconds with 9 queries, spending 0.0085000991821289 doing MySQL queries and 0.062854766845703 doing PHP things.
