Time Before: 0.00188 seconds
Time After: 0.00241 seconds
Time Before: 0.00248 seconds
Time After: 0.00290 seconds
Time Before: 0.00315 seconds
Time After: 0.00327 seconds
Time Before: 0.00416 seconds
Time After: 0.00679 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00334 seconds
Time After: 0.01119 seconds
Time Taken: 0.00785 seconds
Time Before: 0.01339 seconds
Time After: 0.01380 seconds
Time Before: 0.01553 seconds
Time After: 0.01684 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01260 seconds
Time After: 0.01706 seconds
Time Taken: 0.00446 seconds
Time Before: 0.02252 seconds
Time After: 0.02267 seconds
Time Before: 0.02545 seconds
Time After: 0.02720 seconds
Time Taken: 0.00175 seconds
End call of global.php: 0.029846906661987
Time Before: 0.03135 seconds
Time After: 0.03150 seconds
Time Before: 0.03366 seconds
Time After: 0.03515 seconds
SET lastactivity = 1782860023, location = '/forums/private.php?do=newpm&explain=1&u=95358'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.05100 seconds
Time After: 0.05132 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.050080060958862 seconds with 9 queries, spending 0.0087430477142334 doing MySQL queries and 0.041337013244629 doing PHP things.
