Time Before: 0.02849 seconds
Time After: 0.03365 seconds
Time Taken: 0.00516 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03376 seconds
Time After: 0.03422 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03448 seconds
Time After: 0.03465 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03537 seconds
Time After: 0.03810 seconds
Time Taken: 0.00273 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03472 seconds
Time After: 0.04344 seconds
Time Taken: 0.00873 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05365 seconds
Time After: 0.05486 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05747 seconds
Time After: 0.05869 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05300 seconds
Time After: 0.05900 seconds
Time Taken: 0.00600 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09712 seconds
Time After: 0.09729 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.77965 seconds
Time After: 0.78120 seconds
Time Taken: 0.00155 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.78335976600647
Time Before: 0.81502 seconds
Time After: 0.81517 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.82427 seconds
Time After: 0.82580 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772675256, location = '/forums/private.php?do=newpm&explain=1&u=95378'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.86199 seconds
Time After: 0.86235 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.86090993881226 seconds with 9 queries, spending 0.00954270362854 doing MySQL queries and 0.85136723518372 doing PHP things.
