Time Before: 0.00208 seconds
Time After: 0.00283 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00297 seconds
Time After: 0.00339 seconds
Time Before: 0.00364 seconds
Time After: 0.00377 seconds
Time Before: 0.00457 seconds
Time After: 0.00803 seconds
Time Taken: 0.00347 seconds
Time Before: 0.00384 seconds
Time After: 0.01141 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01435 seconds
Time After: 0.01478 seconds
Time Before: 0.01723 seconds
Time After: 0.01845 seconds
Time Before: 0.01366 seconds
Time After: 0.01862 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02658 seconds
Time After: 0.02680 seconds
Time Before: 0.02946 seconds
Time After: 0.03077 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.032495021820068
Time Before: 0.03395 seconds
Time After: 0.03444 seconds
Time Before: 0.03639 seconds
Time After: 0.03791 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1785275981, location = '/forums/private.php?do=newpm&explain=1&u=95402', badlocation = 1
Time Before: 0.05256 seconds
Time After: 0.05284 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.051527976989746 seconds with 9 queries, spending 0.0094840526580811 doing MySQL queries and 0.042043924331665 doing PHP things.
