Time Before: 0.00180 seconds
Time After: 0.00237 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00248 seconds
Time After: 0.00309 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00339 seconds
Time After: 0.00354 seconds
Time Before: 0.00443 seconds
Time After: 0.00735 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00362 seconds
Time After: 0.01309 seconds
Time Taken: 0.00947 seconds
Time Before: 0.01569 seconds
Time After: 0.01609 seconds
Time Before: 0.01882 seconds
Time After: 0.02027 seconds
Time Before: 0.01488 seconds
Time After: 0.02048 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02615 seconds
Time After: 0.02632 seconds
Time Before: 0.02834 seconds
Time After: 0.02965 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03403 seconds
Time After: 0.03420 seconds
Time Before: 0.03648 seconds
Time After: 0.03794 seconds
UPDATE session SET lastactivity = 1783148221, location = '/forums/private.php?do=newpm&explain=1&u=95467', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.05394 seconds
Time After: 0.05424 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
