Time Before: 0.01307 seconds
Time After: 0.02368 seconds
Time Taken: 0.01061 seconds
Time Before: 0.02377 seconds
Time After: 0.02422 seconds
Time Before: 0.02445 seconds
Time After: 0.02459 seconds
Time Before: 0.02537 seconds
Time After: 0.02765 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02465 seconds
Time After: 0.03234 seconds
Time Taken: 0.00769 seconds
Time Before: 0.04429 seconds
Time After: 0.04473 seconds
Time Before: 0.04753 seconds
Time After: 0.04872 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04355 seconds
Time After: 0.04894 seconds
Time Taken: 0.00539 seconds
Memory After: 2,261.836 KB
Time Before: 0.07611 seconds
Time After: 0.07627 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09594 seconds
Time After: 0.09726 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.11299 seconds
Time After: 0.11316 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11583 seconds
Time After: 0.11726 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788935632, location = '/forums/private.php?do=newpm&explain=1&u=95607' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13723 seconds
Time After: 0.13769 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
