Time Before: 0.00891 seconds
Time After: 0.01200 seconds
Time Taken: 0.00309 seconds
Time Before: 0.01208 seconds
Time After: 0.01254 seconds
Time Before: 0.01283 seconds
Time After: 0.01297 seconds
Time Before: 0.01361 seconds
Time After: 0.01552 seconds
Time Taken: 0.00192 seconds
Time Before: 0.01303 seconds
Time After: 0.02000 seconds
Time Taken: 0.00697 seconds
Time Before: 0.02586 seconds
Time After: 0.02606 seconds
Time Before: 0.02910 seconds
Time After: 0.03060 seconds
Time Taken: 0.00150 seconds
Time Before: 0.02516 seconds
Time After: 0.03085 seconds
Time Taken: 0.00569 seconds
Time Before: 0.05687 seconds
Time After: 0.05701 seconds
Time Before: 0.06542 seconds
Time After: 0.06667 seconds
Time Before: 0.07591 seconds
Time After: 0.07610 seconds
Time Before: 0.07858 seconds
Time After: 0.08003 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=9575' WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.09609 seconds
Time After: 0.09635 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
