Time Before: 0.00200 seconds
Time After: 0.00263 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00272 seconds
Time After: 0.00335 seconds
Time Before: 0.00358 seconds
Time After: 0.00370 seconds
Time Before: 0.00438 seconds
Time After: 0.00684 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00375 seconds
Time After: 0.01033 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01207 seconds
Time After: 0.01225 seconds
Time Before: 0.01463 seconds
Time After: 0.01584 seconds
Time Before: 0.01151 seconds
Time After: 0.01601 seconds
Time Taken: 0.00450 seconds
Time Before: 0.02088 seconds
Time After: 0.02106 seconds
Time Before: 0.02318 seconds
Time After: 0.02444 seconds
End call of global.php: 0.026059150695801
Time Before: 0.02737 seconds
Time After: 0.02781 seconds
Time Before: 0.02973 seconds
Time After: 0.03117 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=95950', badlocation = 1
Time Before: 0.04348 seconds
Time After: 0.04374 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.042582035064697 seconds with 9 queries, spending 0.008185863494873 doing MySQL queries and 0.034396171569824 doing PHP things.
