Time Before: 0.00133 seconds
Time After: 0.00177 seconds
Time Before: 0.00183 seconds
Time After: 0.00232 seconds
Time Before: 0.00256 seconds
Time After: 0.00273 seconds
Time Before: 0.00338 seconds
Time After: 0.00644 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00279 seconds
Time After: 0.00984 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01196 seconds
Time After: 0.01240 seconds
Time Before: 0.01494 seconds
Time After: 0.01638 seconds
Time Before: 0.01129 seconds
Time After: 0.01656 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02190 seconds
Time After: 0.02216 seconds
Time Before: 0.02429 seconds
Time After: 0.02555 seconds
End call of global.php: 0.027268886566162
Time Before: 0.02858 seconds
Time After: 0.02875 seconds
Time Before: 0.03084 seconds
Time After: 0.03229 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=95956', badlocation = 1
Time Before: 0.04475 seconds
Time After: 0.04507 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043751001358032 seconds with 9 queries, spending 0.0090796947479248 doing MySQL queries and 0.034671306610107 doing PHP things.
