Time Before: 0.01654 seconds
Time After: 0.02312 seconds
Time Taken: 0.00658 seconds
Time Before: 0.02322 seconds
Time After: 0.02361 seconds
Time Before: 0.02384 seconds
Time After: 0.02396 seconds
Time Before: 0.02487 seconds
Time After: 0.02731 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02406 seconds
Time After: 0.03169 seconds
Time Taken: 0.00763 seconds
Time Before: 0.04171 seconds
Time After: 0.04216 seconds
Time Before: 0.04480 seconds
Time After: 0.04599 seconds
Time Before: 0.04097 seconds
Time After: 0.04620 seconds
Time Taken: 0.00523 seconds
Time Before: 0.07723 seconds
Time After: 0.07740 seconds
Time Before: 0.08839 seconds
Time After: 0.08969 seconds
Time Before: 0.10394 seconds
Time After: 0.10428 seconds
Time Before: 0.10668 seconds
Time After: 0.10813 seconds
UPDATE session SET lastactivity = 1785423878, location = '/forums/private.php?do=newpm&explain=1&u=96081' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.12667 seconds
Time After: 0.12701 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
