Time Before: 0.00145 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00249 seconds
Time Before: 0.00271 seconds
Time After: 0.00284 seconds
Time Before: 0.00377 seconds
Time After: 0.00709 seconds
Time Taken: 0.00332 seconds
Time Before: 0.00291 seconds
Time After: 0.01202 seconds
Time Taken: 0.00911 seconds
Time Before: 0.01486 seconds
Time After: 0.01508 seconds
Time Before: 0.01824 seconds
Time After: 0.01950 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01401 seconds
Time After: 0.01977 seconds
Time Taken: 0.00577 seconds
Memory After: 2,261.836 KB
Time Before: 0.02625 seconds
Time After: 0.02650 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02872 seconds
Time After: 0.02993 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.03168797492981
Time Before: 0.03298 seconds
Time After: 0.03314 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03565 seconds
Time After: 0.03710 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789061199, location = '/forums/private.php?do=newpm&explain=1&u=96088', badlocation = 1
Time Before: 0.05764 seconds
Time After: 0.05792 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.056336879730225 seconds with 9 queries, spending 0.0087718963623047 doing MySQL queries and 0.04756498336792 doing PHP things.
