Time Before: 0.02981 seconds
Time After: 0.03854 seconds
Time Taken: 0.00873 seconds
Time Before: 0.03866 seconds
Time After: 0.03912 seconds
Time Before: 0.03934 seconds
Time After: 0.03953 seconds
Time Before: 0.04028 seconds
Time After: 0.04319 seconds
Time Taken: 0.00291 seconds
Time Before: 0.03959 seconds
Time After: 0.04724 seconds
Time Taken: 0.00765 seconds
Time Before: 0.05729 seconds
Time After: 0.05764 seconds
Time Before: 0.06007 seconds
Time After: 0.06135 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05666 seconds
Time After: 0.06160 seconds
Time Taken: 0.00494 seconds
Memory After: 2,261.836 KB
Time Before: 0.10005 seconds
Time After: 0.10031 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12241 seconds
Time After: 0.12369 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12596082687378
Time Before: 0.13946 seconds
Time After: 0.13962 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14239 seconds
Time After: 0.14388 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788901061, location = '/forums/private.php?do=newpm&explain=1&u=96154'
Time Before: 0.16308 seconds
Time After: 0.16344 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.16197490692139 seconds with 9 queries, spending 0.00874924659729 doing MySQL queries and 0.1532256603241 doing PHP things.
